 Home > PRODUCTS > MILITARY EQUIPMENT > HANDSET > Handset H-250 (H-250U st.)
    KT-H350/U (H-350/U st.)
Funcitional Description :
Handser KT-H350(H-350/U st.) (E.M.I. Cable) is a KT-PRC77(AN/PRC 77 st.) or KT-PRC25(AN/PRC-25) the Microphone and Receiver dynamic and noise cancelling.
 Technical Description(Microphone)
   - Normal Impedance : 150Ω ± 30
   - Frequency : 300 ~ 3,500 Hz
   - Sernsitivity : -56dB (1kHz)
 Technical Description(Earphone)
   - Normal Impedance : 1,000 Ω ± 200
   - Frequency : 500 ~ 3,500 Hz
   - Sernsitivity : 105dB ± 3 (1kHz)
Environmental Limitations Equipment Operation
   - Elevation : up to 15,000 feet above sea level
   - Relative Humidity : up to 97 percent
