 Home > PRODUCTS > MILITARY EQUIPMENT > HANDSET > KT-H350U/K (H-350U/K st.)
Handset KT-H350U/K(H-350U/K st.) is a use the KT-PRC77(AN-PRC 77 st.) the Microphone and Receiver Change Type.
Technical Description
Microphone
   - Normal Impedance : 150 Ohm +- 30 (standard temperature)
     - Frequency : 300- 3,500 Hz
     - Sensitivity : -56 dB (1 KHz)
Earphone
    - Normal Impedance : 1,000 Ohm +- 200 (standard temperature)
    - Frequency : 500- 3,500 Hz
    - Sensitivity : 105 dB +-3 (1 KHz)
Environmental Limitation Equipment Operation
    - Elevation : up to 15,000 feet above sea level
 - Relative Humidity : up to 97 %
