 Home > PRODUCTS > MILITARY EQUIPMENT > HANDSET > KT-H350U/K (H-350U/K st.)
    KT-H60/PT (H-60/PT st.)
Technical Description
Earphone KT-TA235/PT (TA-235/PT st.)(5965-566-1639) SM-C-208021
    - Sensitivity : 116 dB ( 1 KHz )
   - Impedance : 150 Ohm +- 10% (1 KHz)
   - Frequency : 300 - 3,200 Hz
▷MICROPHONE : KT-TA117/PT (TA-117/PT st.)
   - Type : Carbon Granule
  - Sensitivity : -52 +- 5dB (1KHz)
   - Impedance : 35 ohm +- 3.5 ohm
  - Frequency Range : 300~ 4,000 Hz
  - Noise : less than 96dB
SWITCH : SA-129/PT
CABLE : CX-2151 RETRACTABLE CORD
Environmental Limitation Equipment Operation
   - Input
     Operating Current : 125 mA (maximum)
   - Output
     Nominal Resistance : 35 Ohms
     Frequency Range : 500~ 4,000 Hz
