 Home > PRODUCTS > MILITARY EQUIPMENT > FIELD TELEPHONE SET > KT-TA312/PT (TA-312/PT st.)
▶ Purpose and use
   The KT-TA312/PT (TA-312/PT st.) is a two-wire. Battery-operated field
   telephones it may be used in a simple point-to point
   voice frequency (vf) wire communication link any
   two-wire rundown subscriber position of a telephone
   communication system.
▶ Technical Character
 ▷ Voltage requirements : 3 volts D.C. (BA-30)
 ▷ Frequency range : 300∼3,200 Hz
 ▷ Signaling
 ▷ Signaling
     Frequency -----------20 Hz
     Voltage ------------- 90∼100 volts
 ▷Station-to-station
 ▷Net Weight : 4.35 Kg
Wire description and type or gage
Maximum distance (miles)
Field Wire WD-1/TT
Wet ------- 14. Dry ----- 22
Field Wire WD-14/TT
Loaded ---- 22. Dry ----- 14
Spiral-for cable CX-1065/G
29
Lead-covered cable, 19-gage
30
Open-wire lines, W-2 #14 AWG copper
230
Open-Wire lines, W-74 #12 AWG copper
520
▶ Parts Assy List
No.
Parts No.
Description
1
5965-669-9145
Handset (H-60/PT)
2
5915-506-1469
Generator (G-42/PT)
3
5805-506-1145
Net Work (CU-350B/PT)
4
5805-382-6857
Buzzer (BZ-23/PT)
5
5805-392-7726
Harness Cable
6
5940-545-8187
Crank Hand
7
5999-502-9486
Terminal Panel
8
5995-665-7390
Contact Assy
9
5930-504-9486
Cord Assy (CX-2151/U)
10
5995-665-7390
PTT Switch (SA-129/PT)
11
5930-301-5866
Spring Helical Torsion
12
5805-301-3865
13
5930-399-7773
Selector Rotary Switch
14
5930-173-8358
Switch Cover
15
Pranger Assy
16
5930-566-1639
Ext-int Rotary Switch
17
5965-549-0220
Earphone Element (TA-235/PT)
18
5965-925-5112
Microphone Element (TA-117/PT)
19
5805-392-7937
Contact Housing
20
Gasket
21
6135-681-8597
Battery Cover Assy
22
5940-5556-7802
Binding Post Assy
23
5930-566-1638
Hook Switch
24
5935-549-2646
Connector (U-79/U)
