 Home > PRODUCTS > MILITARY EQUIPMENT > OTHER ELEMENTS > KT-M80/GR (M-80/GR st.) Microphone
    KT-H189/GR (H-189/GR st.) Earphone
Type : Dynamic
Sensitivity : 105 +1 3dB(1KHz)
Impedance : 1,000 ohm +- 200 ohm
Frequency Range : 0.3 ~ 3.5KHz
Termination : Contact pin 1.2 pie
Dimensions(mm) : 41.2 pie x 13.1
Weight : 50.8g
Ambient Temperature : -20 ~ 60
Humidity : Max 95% RH
Use : Hand set (H-189/GR st.), (AN/PRC-77 st.)
FSN : 5965-933-6897(SM-C-544262)
