KT-M139/G (M-139/G st.) Earphone
SPECIFICATION Model No. | M-139-1 | M-139-2 | M-139-3 | M-139-4 | Military Type | H-143/AIC | N/A | Type | Dynamic | Sensitivity | 105dB(1KHz) 1MWRMS | 105dB +-3dB(1KHz) | 105dB +-3dB(1KHz)< | 105dB(1KHz)< | FrequencyRange | 100 ~ 5,500Hz | 300 ~ 4,000Hz | 100 ~ 5,000Hz | 100 ~ 3,500Hz | Impedance | 19 ohm | 300 ohm | 600 ohm | 1,000 ohm | Termination | Screw(2-56unc) plug hole dia 2.2pie | Dimensions (mm) | 50.4 pie x 13.2 | Temperature range | -55 ℃ ~ 71℃ | -120 ℉ ~ 150 ℉ | -55℃ ~ 71℃ | -120 ℉ ~ 150 ℉ | Peril Spec | MIL-E-25670 | N/A | MIL-E-25670 | MIL-H-49161 | FSN | 5965-615-0104 | N/A | N/A | 5965-135-0506 |
