 Home > PRODUCTS > MILITARY EQUIPMENT > OTHER ELEMENTS > KT-M139/G (M-139/G st.) Earphone
    KT-M138/G (M-138/G st.) Microphone
Type : Dynamic
Sensitivity : More Than -56 dB(1KHz)
Impedance : 150 ohm +- 15 ohm
Frequency Range : 0.3 ~ 3.5KHz
Termination : Screw(2-56unc) Plug Hole dia 2.1 pie
Dimensions(mm) : 28.6 x 54.6 x 18.2
Weight : 18g
Ambient Temperature : -40 ~ 150
Humidity : Max 95% RH
Use : Crew Man's Radio Helmet (MK-1039/G st.), (MK-1697/G st.)
FSN : 5965-937-1851
